ls1 lifter install...
i searched and searched ...theres a oil hole on the side of the stock lifters...does the hole get installed up towards the intake or down towards the piston?
Originally Posted by BIG_MIKE2005
Well guys you can only install the lifters one way. The roller has to be on the cam lobe. If you try to flip it over your gonna have big problems. And the flat sides need to run toward the front end for the lifter trays to fit back over the new lifters.
