TDC method for valvespring change
Re: TDC method for valvespring change
you need to have the piston at TDC for each pair you do or the valves will fall down into the cylinder. basically just watch the intake valve go as high up as it can and then do that set of springs. or use a screw driver in the spark plug hole and turn over the motor till it slides out.
ur in charlotte i see btw...i'm right in fort mill...i can help you out if you want. got a garage and lots of tools. just reply to this.
i appreciate all the help offered Paul, but i sort of want to do it by myself, because i just want to be able to say that I built my car and no one else... ya know?? this is my first cam install, and i NEED help but just too stupid to take it... LOL... thanx a bunch though!!!!!!!
mike
mike
oh yeah... do you have to have some type of NYLON ROPE inserted in the spark plug hole or somthing??????
thanx!
mike
thanx!
mike
well if i remember correctly that's for if you have an automatic and you don't want the motor to turn over when your taking off the crank pulley. there's alot of work involved with it. i did it a different way if i remember correctly, but i don't really remember. i think i put my pulley puller on there and then stuck a pry bar in between there and just pulled and pulled and it finally came off. if you need any help though man i'm here. or any tools. i know you'll need a 24mm socket. i'm 18 btw and i don't do anything so i'm always here. ttyl ew btw what cam are you puttin in?
thanx for all the help paul... im only 19 and i have nothing to do right now as well.. LOL. im putting in the gm ASA cam 226/236 110 lsa
mike
mike
damn...i wanna hear this when this thing...its gonna cam like a bitch. did you get the computer redone for that? seriously i wanna hear your car when your done with it. we'll have to meet up or something.
!LS1 11 Second Club
Yeah, please post your ASA results!!! Shoot, I wish people in South Florida were as nice as they are in SC. Now that's a way to help each other out.
