Can 918's be run to .600 lift safely???
Old 07-22-2007, 03:52 PM
99LS1T/A's Avatar
Default Can 918's be run to .600 lift safely???
The cam I have has lift at .580 intake and .600 exhaust....Would I be ok,if I ran the 918's with this cam??? I ran the 918's with the F13 cam in my other car and it was fine at .595...Thanks for any help
Old 07-22-2007, 03:57 PM
Websy21's Avatar
I too was curious about those springs and my cam but it is only .581/.588, not sure what I will do yet if nobody drops in but I don't think I would run that cam with those springs myself. I really think tha is pushing it, I have heard a few bad things about these springs??????
Old 07-22-2007, 04:15 PM
JPH
JPH's Avatar
yes you can run those with up to .600 lift, as long as you are not to short on your install height.
Old 07-22-2007, 06:02 PM
Raise's Avatar
ive seen guys run 918s with cams slightly over .600 lift, but personally i wouldnt do it. the price of dual springs is not that much more...and u have that added security. believe me, you dont want a spring to break
Old 07-22-2007, 06:38 PM
vettenuts's Avatar
Why not get the PAC 1518's, better lift, better spring.
Old 07-22-2007, 07:25 PM
Moderator
davered00ss's Avatar
918's are good to .600 lift. I would not push it. Go with a good dual spring good to .650 lift. Why take a chance for an extra $50 for springs.
Old 07-22-2007, 08:13 PM
Yeahdoug's Avatar
PAC-1518 will take .600 lift installed at 1.750" if you want a little more seat pressure. Or .650" lift at the normal 1.800" IH.
Old 07-22-2007, 08:27 PM
91Z28's Avatar
I have a set of 1518s I'm going to use with a cam that produces .612/.606 lift, what installed height do you recommend?
Old 07-22-2007, 09:29 PM
Yeahdoug's Avatar
You could get away with 1.750-1.760.
Coil bind is ~1.080 so there's some room to play around with.
Old 07-22-2007, 09:48 PM
91Z28's Avatar
Thanks for the info! I was hoping I could install them at 1.75 for the added pressure.
Old 07-22-2007, 09:50 PM
BayAreaSS's Avatar
Can the 918's be ran with the Torquer v2 or should the dual springs be used?
Old 07-22-2007, 09:51 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Springs, like rods have an added cushion built into them. If you already have some 918s that aren't worn out I'd use them.
Old 07-23-2007, 01:49 PM
Moderator
LIL SS's Avatar
I ran 918's with a TR236 (.595 intake .591 exhaust) for about 7500 miles before I sold the car. No issues.
