? flow = HP
Old 05-16-2003, 07:57 PM
Bink's Avatar
Default ? flow = HP
I know I've seen this. I can't find it! What # of CFM roughly equals 1 HP? TIA
joel
Old 05-16-2003, 08:02 PM
LEO
LEO's Avatar
Default Re: ? flow = HP
I've wondered the same thing, some brainiac on this site has to have the answer to this query.
Old 05-16-2003, 08:16 PM
Bink's Avatar
One of the head flow gurus said it ,i printed it and now I can't find it! I searched in the archives and I Googled this site and others.
Old 05-16-2003, 09:11 PM
Crazyquik's Avatar
I've heard 2.2 cfm/hp, how's that sound?
Doesn't sound right to me, I'm checking my records trying to find what Warren Johnson said.
J.
Old 05-16-2003, 09:18 PM
Demon SS's Avatar
here is what I have
hp=.25714 x cfm x no. of cylinders
or
flow (in cfm @28ins)
100= 205.7 potential hp
200= 411.4
300= 617.1
400= 822.8
500= 1028.6
Old 05-17-2003, 01:18 PM
Bink's Avatar
So I guess it's between 2.2.and 2.6 cfm per HP.If you use DEMON SS equation and plug in 10 cfm total flow it's 2.57cfm/HP.
Thanks Crazyquik and DEMON SS!
Old 09-26-2008, 10:36 PM
SHARKZ33's Avatar
I found this I was curious myself. http://www.bgsoflex.com/flowcalc1.html
Old 09-26-2008, 10:42 PM
1989GTA's Avatar
For a V8 I have always used 2.056hp/cfm.
Old 09-28-2008, 12:11 PM
Super Hulk Smash
JakeFusion's Avatar
Yeah, 2.06 is the standard for a V8.
Old 09-28-2008, 06:12 PM
KCS
Moderator
KCS's Avatar
From Superflow:
2.0 Air Flow Through Engines
The power of an engine is directly proportional to the amount of air drawn into the cylinder and retained until ignition occurs. By reducing the air flow resistance of the intake and exhaust tract, cylinder filling is improved and engine power is increased directly.
The average air flow through each engine cylinder can be estimated as follows:
(1) Average air flow (cfm) = 1.67 x HP per cylinder
(2) Average air flow (l/s) = 1.06 x kW per cylinder
The maximum intake air flow rate for a single cylinder will be about 2.5 times the average airflow for the cylinder because the intake occurs during only 40% of the total cycle.
For example, if a Chevrolet V-8 engine produces 440 HP, the power per cylinder is 55 HP.
Average Air Flow = 1.67 x HP = 92 CFM (43.4 l/s)
Avg. Intake Rate = 2.5 x 92 CFM = 230 CFM (108 l/s)
Peak Intake Rate = 2.5 x 230 CFM = 575 CFM (271 l/s)
Old 09-29-2008, 12:03 AM
KMS.1320's Avatar
If only HP per CFM worked in the real world! Heads that flow less CFM can often make more power than heads that flow more CFM.
