oil starvation?
Old 07-24-2007, 01:34 PM
mulot30th's Avatar
Default oil starvation?
I noticed that when I launch my TransAm very hard (like at the track with tires hooking in 1st gear), my oil pressure drop to like 30psi, then as I shift 2nd gear, pressure climbs back to 60-80psi.
During the burnout, when I hold the brake and WOT, oil pressure is at 70psi, when I release the linelock and the tire hooks, oil pressure drops down to 30 psi again...
Sounds like pumps gets some air instead of oil... maybe I should consider overfilling engine oil?
Old 07-24-2007, 01:50 PM
brad8266's Avatar
You may need to fill it a little more. Also your pump could be on the way out the door possibly.
Old 07-24-2007, 02:13 PM
mulot30th's Avatar
Its new oil pump (has 1000 miles on it)
Old 07-24-2007, 02:23 PM
WS6NIGHTMARE's Avatar
Just check your oil level before you go out racing. You dont want to overfill it though. I dont think you have anything wrong, just the oil moving around a little under force.
Old 07-24-2007, 02:37 PM
mulot30th's Avatar
Doesn't it hurt motor getting that low pressure for about 1-2 seconds WOT at the track?
Old 07-24-2007, 02:44 PM
The oil doesnt stop flowing, just slows down for a split second, if it dropped to 0, then I would be very concerned. Maybe a baffle system would improve the situation.
The only other fix I see for you is stop launching it, but like I said, I dont think anything is wrong here.
By all means call a vendor and ask one of the experts opinion.
Old 07-24-2007, 03:18 PM
bczee's Avatar
If your going to continue drag racing it and having them hard launches, I would suggest looking into a aftermarket pan that has the pickup at the rear most end of the slump. Or modify yours to add a baffle behind the pickup area to assist in keeping the oil around the pickup during the launch.
Old 07-24-2007, 10:17 PM
mulot30th's Avatar
that is what I will do
Old 07-28-2007, 12:00 PM
mulot30th's Avatar
Here is an in car video, you can see oil pressure in the center gauge.
OIl pressure drops each time I get traction in 1st gear as you will see.
Click here to watch In-car-nitrous-run
Old 07-28-2007, 12:11 PM
Good looking run. Just may need another baffle in the pan. but since you have aftermarket gauges, I might hook the stocker back up just to see if it does the same thing. If it does then you know its not the gauge.
Old 07-30-2007, 09:48 AM
mulot30th's Avatar
I would like to know, but I have no plan on going back to track before fixing my oil problem...
Old 07-30-2007, 09:59 AM
Well then your definitely going to have a hard time determining if its the gauge or not.
