guys help me spend 4000$
Old 07-26-2007, 02:41 PM
99DWPTA's Avatar
Default guys help me spend 4000$
i have a fast 9090 combo sitting in my room so far.
i have 4000$ in the bank to spend on new parts
car has following mods
slp long tubes gmmg
msd coilpacks msd wires
slp intake
NOW whats the best way to produce power with 4k and be able to do fueling and everything.
this is for a stock bottom end 346 2001 trans am
this will be on a stalled A4
Old 07-26-2007, 02:44 PM
MPHmotorsports's Avatar
I can help you spend that 4K and get you some great HP at the same time.
Give me a call.
Thanks
Jeremy
Old 07-26-2007, 02:53 PM
99DWPTA's Avatar
i'm sure anyone can help me spend 4k. i wanna be able to atleast make 450whp??? is this possiable?
Old 07-26-2007, 02:55 PM
99DWPTA's Avatar
i was thinking maybe
cam and nitrous. or would cam and head be better?
Old 07-26-2007, 02:58 PM
andrew69_04's Avatar
you could give me $3000. and put $100o into a Wet system.....and maybe a few electric superchargers....then you might hit your goal and we both will be happy
Old 07-26-2007, 03:03 PM
00TurboTA's Avatar
i would say do the rear mount like i have and buy an intercooler too...but if ur going N/A then i would get heads and a cam. its all u in the end tho
Old 07-26-2007, 03:11 PM
Disturbed Bird's Avatar
buy trickflow 215 heads, a cam and a ported fast 90 intake
Old 07-26-2007, 06:09 PM
mudflap1989's Avatar
You really have to do your research and answer this question for yourself, because you will get many different opinions and many of them will be good, it is just up to want you want. I personally love the sound of a big cam, so I suggest heads, cam and nitrous. Read here on LS1Tech and call some of the sponsors to decide what you want. You might could do a supercharger or somekind of turbo system. I'm not really sure about prices, you might have to get a used system if your budget is 4k.
You also need to think about the transmission. Is the stall included in the 4k and most likely you will have to invest $1,500-$2,000 on a transmission. Some people do this in different ways, some beef up the drivetrain first and then build the motor. Some people build the motor first but then when they tear their rear-end or tranny up, they have no money to fix it. This is something that you should think about.
Old 07-30-2007, 03:09 AM
burnrubr88's Avatar
I would do H/C and converter now and then just wait for your tranny and rearend to go and replace those.
Old 07-30-2007, 06:17 AM
markp03's Avatar
depends on your end goals... if you just want some more power and thats it thats all your not going bigger....get a nice set of heads and a decent cam. that and your fast 90/90 will get you close to that 450hp mark. but if you want to go bigger then that. you need to consider, are you going to use N2O? or do you want to do FI? I will tell you from experiance that FI is expensive!! way more so then you thinki it will be =). if not you need a bigger motor like a 408. which you can get a small block for right around 4k
figure out your end goals so you dont end up wasting money on parts that will be replaced later.
Old 07-30-2007, 01:23 PM
snake charmer's Avatar
heads and cam is about 1500 and that alone will get you close to 450 .
might wan to look for some really good wheels and tires .
is this going to be drag or street o rboth ?
may want to think about nos and or a rearend(2k) ,
suspension like a kmemebr a arms , shock,coilovers ,
Old 07-30-2007, 01:32 PM
jmdale1984's Avatar
Don't forget to grab a UMI Chassis Mount Torque Arm. I'm a poor modder, but I needed a new torque arm, and I never could have guess it would have made such a difference.
Old 07-30-2007, 02:49 PM
408 z28's Avatar
heads,cam,spray,stall,tune
Old 07-31-2007, 07:43 AM
turkey's Avatar
Like Mudflap said it depends on what you want to do with the car. If you are looking for a drag car then I would say H/C, juice, and a good tune. If you are looking for autocross then go with suspension first.
If you are looking for 450 and nothing more (not gonna happen) then you could go H/C then do a little suspension. Really you just need to decide how far you want to go. If the car is a DD the mods are going to be different than if the car is primarily track.
Once you decide what you want (drag, autoX, or cruiser) and determine usage of the car in the future (track, weekends, or DD) then we will be able to give more input.
Old 07-31-2007, 04:59 PM
Asmodeus's Avatar
A heads/cam combo isprobably not going to make 450rwhp through a stalled A4.. a better question would be.. I want to run 10's and I have XXXX money.
Old 07-31-2007, 08:57 PM
transamfreak01's Avatar
if it were me i would buy a trans and a rear end that way once you put down 450 to the wheels they wont break. with that you can do a lot more
