What cam would the public recommend for...
... my setup (sig). Heard that bigger tends to suck w/ much below 4.10s so i'm wonderin' if my 3.73s will cut it?
Also, i'm lookin' for low end to mid range power, not soo much up high. Any opinions or suggestions on the grind? I got till Xmas to make my decision and do my research so plenty of time. Thanks for the help. Btw, daily driver.
*EDIT*
My goals are
- 400 HP if possible w/ just a cam swap
- Low to mid range power (not soo much higher cause i don't wanna F w/ my drivetrain)
- Good lobe sound (i like it to chug)
- Pretty aggressive
- Budget is around 1 grand (not including install, possibly not including tune, haven't researched that enough yet)
*EDIT*
My goals are
- Pretty aggressive
Sex On Wheels
Actually I'm VERY happy with my 230/236 right now. I bumped the compression quite a bit and unlike what I've been hearing a lot, my power down low is perfectly fine. It definitely picks up after 3-3500 but power before then is still better than it was. I still have 3.42's also.
William
William
Depending on how aggressive you want to go I've seen great results with the G5X1 and G5X2 (both from LG Motorsports). Since the public doesn't know the actual specs on the G5X3 I can't offer my opinion on it (also I would never buy a cam where I didn't know specs - I don't care for the "secretive" bullshit).
I'm looking to run either a 228/232 112 LSA or a 236/242 112 LSA. I am leaning towards the smaller of the two due the powerband coming on sooner in the RPM range.
Keep us posted. Good luck
Originally Posted by Vrbas
I've heard alot about the TR 230/224, any opinions in relation to my goals w/ this cam?
- Pretty aggressive
it pretty much fits all these requirments, go to ls1 sounds and look for clips of the CETA hes running this cam
I just bought a Futral F13 yesterday...i did my research and have heard nothing but good things about this cam. It definitely has the sound you're looking for. From what i've heard, it makes really good power down low, and rediculous power in the midrange and up top! with your M6, the bolt ons you have, and the underdrive pulley you plan on getting, you will definitely be above your 400rwhp goal. Do some research on this cam (type f13 in the search box) and go to the video section and type the same thing so you can hear how it sounds. FYI i got mines on a 112(sounds better). The complete specs are 230/232 .595"/.585" 112 or 114. I think this cam is exactly what your looking for...ask some of the guys who have it...with AFR heads and full bolt-ons, some M6 guys have made very usable power in the 480rwhp range. read these links:
https://ls1tech.com/forums/dynamometer-results-comparisons/580073-new-afr-f13-ported-fast-numbers.html
https://ls1tech.com/forums/generation-iii-internal-engine/708263-futral-f13-torquer-2-a.html
I would go with a 224/228 on XE-R lobes and comp 918 springs with some chromemoly pushrods (stock length), 110 LSA +4 degrees advance ground in. Replace the timing chain with an LS2 chain while you're in there, and a ported/shimmed LS6 oil pump if you're feeling nutty!
The cam would still have 6 degrees of overlap making for a nice lope that says something, but doesn't scream it!
Originally Posted by cws T/A
234/242 .598''/.610'' 112+4
Looks to be very similar to the larger of the two cams I am considering, which is a 236/242 .605"/.609" 112 LSA. Now I can finally give the to the G5X3.
Should work fine without flycutting when upgrading to aftermarket milled cylinder heads as well from what I was told about the cam spec'd for me
Ive read were one measured the p/v clearance on a stock ls1 with a g5x3 on a 112 and it was .075 ''.
The safe zone is what .100 '' / .080 '' so take that # for that one particular engine measured .
Flycutting .100/.100 would put it very safe even with milled cylinder heads and a .040 thickness headgasket . The added compression would make the power more and the drivabilty would be similar to a smaller duration cam .
https://ls1tech.com/forums/showthread.php?t=580073
https://ls1tech.com/forums/showthread.php?t=708263
As far as that chart goes (comparing 224 and 230), they look to be pretty close. Sure the 230 makes a little more, but if i went w/ the 230 would i risk having to expand my budget?
Dang dude, really appreciate all the info and the links. I'll definitely do my research on that cam.
I was just throwing my lil .02 in there based on the cams everyone else was mentioning. I think that based on what you described...the f13 falls in that category. thought it would help with the links that I attached...didn't know you didn't want that much info...i'll keep it simple next time and just say F13...lol
