HP gains on thinner oil
LS1 Tech Administrator
Moved from advanced tech section.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
dude
Originally Posted by gts500
dude the oil is just to lubricate the engine thats it
the only diffrence between synthic oils like 5-30w or 10-30 its the cold start,and the 5-30 will last more longer
the first number only specifys thickness at cold temperatures. The second number is the thickness at operating temp. Theyre both 30 weight oils and therefore will perform similarly.
Now we all know that M1 runs on the thin side, and it may well produce a couple extra HP, but it will also smoke more, allow more blow-by, and will not protect your engine as well.
Originally Posted by tee-boy
Not too sure about that, dude. Pumping a thinner oil shouldn't rob as much hp. Any hp freed up should be delivered to the wheels. The question is: how much hp.
If you're so convinced, why are you even asking? Get to googling and learn what the numbers on the bottle mean.
i dont think oil will reduce any HP , if it so how much? 1 HP more or less??
if more i think your engine is runing on lemon jucie not GAS
just try to imagine how powerfull the engine stroke fire, i dont think there is a chance for the oil to hold up the pistons from flying up when you floor it(if you are using GAS ofcourse)
no offence just kidden
There is more power to be had by controlling oil than changing to another oil. But like all other mods, it isn't cheap. Try keeping the oil off the crank with a crank scraper or something like that.
Thin oil will make more power. Before qualifying, Nextel Cup teams will use thinner engine oil for that extra HP advantage. Then swich back to thicker oil for the long 400-500 mile endurance race.
