bigger cam or a FAST 90/90
Old 07-29-2007, 09:14 AM
Phil'sC5vette's Avatar
Default bigger cam or a FAST 90/90
So I didnt drive my car for about two weeks, and it "gets" slow when parked.
I have a 228R cam on a 114 in the car. I have a Torquer II on a 112 with 7.25 rods, and a gasket kit in the garage on the shelf to install.
Im wonder what is best for the car. I really like the way the car is running now, and Im trying to determine what's best for the car.
Install the TV2 = how much more RWHP= little higher power band. (OR sell it )
or
Install a ported FAST 90/90=how much RWHP= about the same power band.
I guess the question is looking at my sig, Will I get more from the FAST 90/90 or the TV2 cam.
A little brain smoker for Sunday morning
Old 07-29-2007, 09:32 AM
santiago's Avatar
if i were you i would do the bigger cam first, then put your ported fast 90 on. its plain just gonna pull harder than your current cam.
Old 07-29-2007, 09:55 AM
Ws6man2000's Avatar
Location: Ft lewis,Ft sill and thats all i hope.Katy texas
i would go with the bigger cam.... but it seems like you are making pretty good power to begin with. Will the torquer v2 clear those afr 205?????
Old 07-29-2007, 09:56 AM
It's a one or the other thread
Old 07-29-2007, 12:33 PM
transamfreak01's Avatar
yeah go with the cam
Old 07-29-2007, 12:47 PM
Im putting down 425 RWHP / 400 RWTQ with the 228R.
The TV2 should add 15-20 RWHP.
The ported FAST 90/90 should put down about the same power, but im wondering where the power would be.
Old 07-29-2007, 01:18 PM
ProjecT 9's Avatar
I'd go with the 90/90. sell the TV2 and put that money else where. with the 90/90 combo i would think you would pick up power all throughout the powerband with the biggest increase in the higher RPMS. better yet use that money you get from selling the TV2 and get the Fast intake ported/port matched by Tony Mamo! i wont give you a actual figure in rwhp i think you would pick up, but i think it would be a nice gain!
Jon
Old 07-29-2007, 01:25 PM
BriancWS6's Avatar
Phil, how much are your heads milled? What gaskets are you using?
Our setups are quite similar, except my cam is a 228/230 114 vs your single pattern, and the possibility of our mill/gasket specs being different. I am making 446/411 through 4.10s, A/F was 12.8 on the dyno, 12.7ish according to my wideband. 122mph trap speeds with basically a full weight car.
While sticking in the larger 232/234 cam will boost peak power output, you will lose some low-mid range power. I'm just interested in seeing how optimized your current setup is at the moment.
Old 07-29-2007, 01:36 PM
JPH
JPH's Avatar
camshaft is my vote.
Old 07-29-2007, 02:00 PM
My heads are milled -.020 off and I use the stock MLS gasket.
Old 07-29-2007, 06:25 PM
MM98's Avatar
Originally Posted by ProjecT 9
I'd go with the 90/90. sell the TV2 and put that money else where. with the 90/90 combo i would think you would pick up power all throughout the powerband with the biggest increase in the higher RPMS. better yet use that money you get from selling the TV2 and get the Fast intake port matched by Tony Mamo! i wont give you a actual figure in rwhp i think you would pick up, but i think it would be a nice gain!
Jon
I agree & will be doing the opposite of what ur doing... Going to a Fast 90/90 combo & down to a 224/230 cam... Even with 4.10's, I really just don't like this big of a cam for a daily driver.
-Mike
Old 07-29-2007, 10:09 PM
Xtnct00WS6's Avatar
Think of it this way...your car will sound much more badass with the new cam! The intake won't do **** for sound. I vote camswap!
Old 07-29-2007, 10:27 PM
pdd
pdd's Avatar
id go with the intake
Old 07-29-2007, 10:31 PM
Evans752's Avatar
Go with the Fast 90 Intake Im getting ready to. Good Luck
Old 07-29-2007, 11:04 PM
Super Hulk Smash
JakeFusion's Avatar
Intake will give you more. 4 degrees more on the intake using the same lobes (XE-R) is maybe worth 10-15rwhp.
The FAST 90 will be worth 20-25rwhp and not change the dynamics of the car.
Old 07-29-2007, 11:48 PM
Bader-X's Avatar
if you like the cam that you have and just want more power then ported fast 90/90 .....
just think of it this way .... if you didn`t have money for the intake would you install that cam as a forward step in cams and want more cam? or would you just stick to your current cam because it`s good enough and happy with its performance and think no thanks I don`t want to spend the money there then it`s intake and TB time.
Old 07-30-2007, 06:25 AM
This is surprising and differant than I would have thought.
the guys on here seem more to say go with the 90/90
Guys on the Corvette forum say do the bigger cam.
I would have thought the other way around.
Maybe if I saw more results from the same set up where guys just switched from the LS6 manifold to the ported 90/90, ID sell my cam package for a 90/90.
Any one have a dyno from before ported 90/90 and after ? Where did the power range move to.
Old 07-30-2007, 08:21 AM
voda1's Avatar
I'll vote for the intake as you said driveablilty is important. Go one step further and optimize DCR to 8.7:1
Old 07-30-2007, 09:06 AM
carreras's Avatar
Jon
I agree, ported FAST
Old 07-30-2007, 10:29 AM
Big Geek's Avatar
These are my thoughts and only an opinion - I would say install the intake/TB combo first and this is why. As previously stated it is hard to say "exactly" where the power will increase but I personally believe that it will pick up in most of the area that the camshafts useful range is. I am gathering that you plan to put a camshaft in it later on anyhow so I would try the intake first and see what kind of power it produces and where. You never know you may end up being pleasantly surprised and put off the camshaft swap for a good while. Hope this helps.
Jim C.
