CAM Vote- HELP & ADVICE needed
Old 07-29-2007, 11:17 AM
miji_am's Avatar
Question CAM Vote- HELP & ADVICE needed
Hey guys im building my engine and i wanna throw in a cam but im confused which 1 its either .224 224 .581 .581 114 or 224 232 .581 .595 114
i have limited options because of my stock automatic tranny
btw i just bought diamond 3.95 flat pistons & 150 dry nitrous so which cam is more suitable for the nitrous ? and its a daily use car
thanx guys appreciate it.
Old 07-29-2007, 11:29 AM
gts500's Avatar
always when you consider to use nitros the best cam choise will be the cam with more exhaust duration and lift.
so the 224-232 is the best choise or simillar cams .
good luck (and dont worry about the tranny it can handle it)
Old 07-29-2007, 11:39 AM
miji_am's Avatar
thats what i was thinking truely about but many told me that the 224/224 is the best for DD use .
its an A4 dude i wish ur right .
thanx man apprecciate it
Old 07-29-2007, 11:40 AM
miji_am's Avatar
btw hows the 80mm bbk is it worth it ?
Old 07-29-2007, 11:41 AM
Jefro6996's Avatar
If those are the two your are considering youll be fine with the 224/232. its a better cam for the nitrous but youd eb fine with either one.
Old 07-29-2007, 11:47 AM
gts500's Avatar
dont worry man am shure because
i have an A4 and i have try to many cams option and i have 150 nos since 3 years now,and its my DD
let me tell you my cams journy i started with :
comp 216-220 525 535 114
TR 224-224 563-563 114
now g5x3 (specs not released) but i think is 232-242 on 114
so i never had a tranny problem with all those and i tryed nitros
on all of these cams . and it all based of the tuner to make your cam DD.
so go for the 224-232 i really like that cam spec it will give you more peak HP than 224-224 so you can rev more.
Old 07-29-2007, 11:50 AM
gts500's Avatar
yes its worth it if you are not gonna go for FAST intake with 90mm.
plus you need a good ram air and you will feel amazing throttle response plus more 10 hp on the dyno.
Old 07-29-2007, 12:54 PM
miji_am's Avatar
thanx again u`ve been very helpfull btw what would u advise as a good convertor which stall ? TCI tranny <---- do u mean a shift kit
and how did u install the NOS where i mean
im thinking of instlling it the on the air box lid
dry 150 sound enough aint it ?
thanx again
Old 07-29-2007, 02:44 PM
ELMiN8oR's Avatar
thanx again
Dry kit my fiend I prefer going on 100 shots because 150 is allot for a dry kit but why don't you
my advice (I know that you will not listen to me) if you want to go on a 150 shot go with wet kits
Old 07-29-2007, 02:59 PM
JPH
JPH's Avatar
224/224 is what i would put in it, if it was mine.
Old 07-29-2007, 03:05 PM
ELMiN8oR's Avatar
That was my advice
Old 07-29-2007, 04:41 PM
gts500's Avatar
why the wet kit for only 150 shot ??? there is a vette here in the form has
633HP and 600TQ DRY KIT the shot is more 250 of dry?
so dry or wet doesnt matter just do it proper way .
and you recommend the 224 for what reason???
the 224-232 has the same street manners plus little ponies on the top rpm.
if you choose somthin try at least to explain so all of us can understand why.
Old 07-29-2007, 04:56 PM
gts500's Avatar
thanx again
the TCI tranny mean overhaul kit the kit include (clutches,bands,steels,valve body upgrades,servo,shift kit...i dont know wht else) anyway the part number is 378951 pro super kit.
and for a stall i have fuddle racing 3400,you can check yank and VIG too.
for your setup i would have a stall around 3600 or so.
and for the nitros instaliation its verey easy any work shop can do that but for the nosels place you can put it any where before the maf (on the air box would be fine) but not after the MAF the dry kit needs the MAF readings so the COMPUTER will add more fuel.
Old 07-29-2007, 05:09 PM
99blancoSS's Avatar
tr224 112 lsa
Old 07-29-2007, 05:10 PM
ELMiN8oR's Avatar
well the reason is pretty simple.
smooth idle!
i know the 224/232 cam very well and i've seen it in action but Miji wants to buy a cam with a smooth idle. like this car http://www.youtube.com/watch?v=gd6u4i-pFNc
so if you have have a 224/232 idle sound we'll be more than happy to listen cause it will determain weather he is going to buy it or not
Thanks
Old 07-29-2007, 05:26 PM
gts500's Avatar
smooth idle!
Thanks
smooth idle ? cant you see the diffrences between those cams miji mention
it doesnt has much diffrences. for the idle smothness the LSA is the thing to look for, the change between lift and duration will change the idle slightly but the LSA will make it all diffrence like between 114 and 110 .
i had a TR224 before on 114 and it was smooth like what you mention then i swaped to g5x3 it had 234-242 but on 114 LSA the car idle verey nice after tuning its simillar to the 224 but little bit choppy .
so for idle smoothness and DD there is two major things to look for LSA and GOOD TUNER its all based on the tuner.
thnx for the info anyway
Old 07-30-2007, 05:27 AM
miji_am's Avatar
thanx guys
i think i`ve decided on the 224/232 . and the tranny kit.+618 spring kit + pro magnum lifters and that sounds enough to handle the power + good tuning
thanx for the time & advice
Old 07-30-2007, 06:18 AM
markp03's Avatar
go big or go home.
nuff said
Old 07-30-2007, 08:43 AM
gts500's Avatar
ok you are on the right way ,but dont forget to buy the pushrods its highley recommended, get the 7.400 lengh.
good luck
Old 07-30-2007, 12:23 PM
Blk97WS6's Avatar
I have to agree, unless you are planning on a set of bigger injectors as well.
