346ci out 408ci (Iron Block) in
Old 07-29-2007, 10:22 PM
Dynojet Fan
VH5150's Avatar
Default 346ci out 408ci (Iron Block) in
Like the title says... Question is.. what needs to be looked over on the heads???
I have LS6 heads and im gonna keep em.. valve size is 2.00 1.57 I think... (cartek 2x heads)
Im gonna have the chamber opened up to accomidate the larger bore... any other suggestions???
thanks...
Old 07-30-2007, 08:14 AM
gnar-dog's Avatar
I'd say go with some 2.020's, and I bet those extra cubes would love some more cam if you haven't done so already
Old 07-30-2007, 09:54 AM
CRAZYCUTER4.8's Avatar
What Did You Do About The Alternator Bracket?
Old 07-30-2007, 10:11 AM
12secSS's Avatar
Just need to drill the boss, then tap it, for the alternator bracket to mount up.
Old 07-30-2007, 10:18 AM
THANKS.....
Old 07-30-2007, 10:57 AM
blackmambaSS04's Avatar
There are 3 mounting holes 4 the alt and only 1 boss that can be drilled ! one boss is missing its the main one 4 the mount?
Old 07-30-2007, 12:30 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Glad this got moved out of the advanced performance section. I'm noting this as I might be making this change soon.
Old 07-30-2007, 12:51 PM
12secSS's Avatar
You'll be fine with the three bolts.
Old 07-30-2007, 03:48 PM
Dynojet Fan
VH5150's Avatar
wow this went to ****.... what alternator bracket??? only 1 person answered my question???
Old 07-30-2007, 03:57 PM
12secSS's Avatar
It probably went to **** because we would need more info to properly answer your question. 346 -> 408 what? Is the 408 a basic setup, or is it built for 1000rwhp? As posted, what cam, what pistons, any other mods. The 243 heads will bolt up to a 408, beyond that we don't know what you need extra to make it work on your setup. Hence ask **** = **** thread.
Old 07-30-2007, 04:04 PM
Dynojet Fan
VH5150's Avatar
Cam= nitrous cam (not too sure of the specs yet but hyd. roller)
pistons= JE
built to handle 145-150mph traps...
3:42 gear
heads= ls6
trans= 4l60e (rpm trans)
2 stages of nitrous... plate kit + dp system...
anything else???
