LS2 intake on LS1...
Old 07-30-2007, 12:49 PM
delsold's Avatar
Default LS2 intake on LS1...
i have never heard of this, but i saw a ls2 intake on ebay that said it was compatible with ls1/ls6 engines.
is this the truth...or an ebay falacy?
Old 07-30-2007, 12:53 PM
12secSS's Avatar
Yes, it is correct. The LS2 intake flows slightly better then an LS1 and worse then an LS6. Also, the MAP sensor is located in the front, versus in the back like an LS1/LS6 intake. Different fuel rails will be required if I'm not mistaken. Not worth swapping IMHO, just wait for an LS6.
Old 07-30-2007, 12:57 PM
snake charmer's Avatar
it does have the 90mm opening for a 90mm tb . though youwill haveto buy a spacer kit from katech to make it wrok with your injectors and as said the fuel .
Old 07-30-2007, 01:48 PM
delsold's Avatar
Thanks guys. It did say the MAP was in the front, and it had a big throttle body opening. It did however say it was compatible with ls1 injectors and rails.
ill try to find it and post a link if i can
Old 07-30-2007, 10:18 PM
N4cer's Avatar
It's not worth switching to, so it doesn't matter.
Old 08-03-2007, 01:22 PM
Retired Street Racer
Matt D's Avatar
The LS2 is a lot like the LS1 intake. It has a lot of material inside that can be removed to increase power. I have a LS6 intake and ported stock TB now, and am switching to a ported LS2 intake and NW 90mm TB. I will make sure to post the results once I get everything on.
Old 08-03-2007, 01:27 PM
2001CobaltSS's Avatar
It should fit fine.
Old 08-03-2007, 02:14 PM
N4cer's Avatar
How are they going to get inside to port it? The only thing that could be done is port matching, and opening up the snout. Not the work that people call "porting" where the runners are changed.
Old 08-03-2007, 02:41 PM
delsold's Avatar
Matt D i sent you a pm
Old 08-03-2007, 02:56 PM
Matt D's Avatar
The bootom of the intake was removed and then epoxied. Trust me, a lot was removed off of the runners.
