Forged 347 Cam Advice. Please Help
Old 07-30-2007, 08:05 PM
1999ssls1's Avatar
Default Forged 347 Cam Advice. Please Help
What cam would you guys suggest in a forged 347 with flat top Mahle pistons and rods, stock crank, ls6 intake, pulleys, longtubes, and just really full bolt ons. I am either going with ls6 stage 2 heads or maybe TEA stage 2 heads. Neither have been milled. What cam would make the most power and good rpm and torque range?
Old 07-30-2007, 08:51 PM
Randy WS6's Avatar
Im my old 347 , i run the TR- T-Rex and loved the power band.
Old 07-30-2007, 08:56 PM
waterbug1999's Avatar
Yea, you got it built so spin that sucker to 7K for max HP..
Old 07-30-2007, 09:10 PM
Randy WS6's Avatar
Just make shore you get it balanced, I spun my 347 ,7800 rpms and never had any problem for three years, mater of fact i steal have the short block ,thinking of freshen it up and keeping it for a backup
Old 07-30-2007, 09:13 PM
1999ssls1's Avatar
What kind of power do you think the cam I have now would make. Its a comp 597-610-234-243 on a 110. How much does balancing run?
Old 07-30-2007, 09:25 PM
DONAIMIAN's Avatar
It should be included in the price of the short block.
Old 07-30-2007, 09:31 PM
That cam is ver similar to the X3 cam.. It will make descent power, but I think a little bigger cam would not hurt.
Old 07-30-2007, 09:38 PM
1999ssls1's Avatar
I am building the short block. You guys think I need a little bigger?
Old 07-30-2007, 09:41 PM
Randy WS6's Avatar
Most machine shops charge around 150.00 to 250.00 for a balance job.
Old 07-30-2007, 09:47 PM
You also need to keep into consideration about clearance issues as well, so bigger might not work though with flat pistons....
Old 07-31-2007, 01:21 AM
Tom@SpeedInc's Avatar
SI5 cam (231/237 .595/.598 112)
Old 07-31-2007, 07:28 AM
1999ssls1's Avatar
I dont think clearance issues will be too big of a problem. They have 4cc valve reliefs. Keep the cams coming
Old 07-31-2007, 03:33 PM
1999ssls1's Avatar
WHich of these would be best for my set up? 244-244-608-612 on a 112 or 234-243-597-610 on a 110
Old 07-31-2007, 03:55 PM
Super Hulk Smash
JakeFusion's Avatar
Vengeance Vindicator 240/244 .608"/.596" 112+4 Camshaft.
Old 07-31-2007, 03:59 PM
1999ssls1's Avatar
I heard it makes good power.
Old 07-31-2007, 04:08 PM
Stang's Bane's Avatar
What do you plan on doing with the car??? Is it a DD or a track only car or a weekend car??
What gears in the rear?? Tranny? Are you going to spray it?? All Motor??
All of these are questions that need to be answered before any valid cam can be suggested. Other than that they are just shots in the dark.
Old 07-31-2007, 05:58 PM
JPH
JPH's Avatar
already gave you my 2 cents. looks like frasier@speedinc agrees on the same profile as well.
Old 07-31-2007, 08:02 PM
1999ssls1's Avatar
Mods are:
M6
3.73s
ls6 intake
42 lb injectors
pulleys
longtubes
ported tb and maf
lid
loudmouth exhaust
forged piston and rods
stock crank
etc
This is a weekend car only. I am wanting to spray it occasionally. Maybe a 150-200 shot. This probably going to be with cnc ported ls6 heads.
Old 07-31-2007, 11:34 PM
mudflap1989's Avatar
It really depends on what you want. What was your old set up, did you have a cam in it, if so what were the specs and how did you like it? So guys like smaller cams, some like bigger cams, it just depends on what you are using it for and what you want out of it. As far as off of the shelf big cams, MS4, Vindicator, G5X4 etc. have made good numbers and good times. I personally went with a Vindicator.
The next step smaller, G5X3, Torquer, F13, F14, etc. have all been proven performers. This might be the range that you want to consider if you are wanting a "good rpm and torque range". The G5X3 is a great cam.
Old 08-01-2007, 07:23 AM
1999ssls1's Avatar
This is a weekend car only. I am wanting to spray it occasionally. Maybe a 150-200 shot. This probably going to be with cnc ported ls6 heads. The old cam was 234-243-597-610 on a 110
