Cam only, or Cam and Heads?
Sup, been doin' research for a new cam and i'm startin' to think, maybe it'd be a good idea to do the heads while i'm at it too (save me another trip to the dyno). I'm lookin' at the TR 230/224 .575/.563 111 LSA (lookin' for low to midrange power and i hear that's a popular one... or maybe it was the 228R from Texas-Speed..... hmmmm).
Anyways, here are my concerns:
- Don't want to spend a ton of money
How much would i be looking for a cam/head package vs. cam only?
- Installin' myself, cam looks fun enough as is
How much harder is it going to be to swap heads while i'm playin' w/ the cam as well?
I'm just brainstormin', what heads would be best for that particular cam? My mods are LID, 3.73 REAR, LT HEADERS (and that's all that's really important) and what would i be lookin' to spend on a decent cam/head package? Thanks for the help.
^^Agreed. And it's a hell of alot easier with reassembly if you do both at the same time. You won't have to worry about droppin a lifter.
I just did my H/C swap in my buddies garage. My first time & my car had 102,000 miles on the clock. I went with a 224/224 .581/.581 114 cam. It's not as aggressive on the valvatrain, it makes proven power & E.T.'s, runs easily on the stock PCM until you can get a tune & is traffic friendly. I mated it with a set of 5.3L heads port/polished & milled .018" by Bo White w/Patriot Gold Dual spring kit & 2.0 intake valves.
Car idles like stock & fires up very easily. The lope isn't real noticable unless your listening for it or on cold start. Might also be louder if I had duals or just a different exhaust than I do. I also have a Bo White port/polished TB & had him do my Lingenfelter intake. I just need the correct fittings for the intake so I can put it on.
Without a tune & runnin a stock LS1 intake I raced a Formula from a low roll & put 4 cars on him by the time I hit 100. The car feels really strong & I know it'll get even better with the intake & full dyno tune. I'm ready to see what this thing will do at the track.
True, but i need to be very conservative w/ my money. I'm tryin' to decide if i wanna do a combo (cost more) or cam only (cost less). I have enough money for both, i'm just tryin' to decide if it's worth it... not to mention i'm doin' the install myself probably, so adding heads is only going to futher complicate the installation.
Im just about to order the TR230 for my car and i have everything priced out. Im buyn the cam, springs, ti retainers, and pushrods from thunder racing and everything else (oil pump, timing chain, gaskets... blah blah) from texas speed. I have everything priced at about $1200 and thats EVERYTHING need to do a cam swap.
I know texas speed sells H/C packages for bout $1800 but you still have to buy gaskets, oil pump, timing chain.... ya kno. So in the end you'll be sittn in the $2100-$2200 range.
Me personally.. im going to do the cam now and in a year or so ill buy a set of AFR 205's with a fast 90/90. Reason being is because i dont have the money to do the whole job now.
Here ya go: http://www.texas-speed.com/shop/item...d=204&catid=47
I'll even take most the guess work out for you to help save some money.
A) get the GM cam bolt & gasket kit
B) go to Autozone & get the FelPro stock LS1 gaskets
C) go with a LS2 chain on your stock gears
D) add some LS7 lifters (can be had for $100 from SDPC)
E) you'll want the pushrod length 7.4 with your stock rockers
oil pump at your own decision. I have a brand new Melling oil pump I didn't use still sitting here in a box, so if you want it let me know. My stock oil pump was working fine at the time of the swap & is still working fine, so I have no use for it.
Originally Posted by Vrbas
So that includes all the tools (air compressor, cam install tool from TR, bolt kits, etc), all the peripherals?
As far as the oil pump goes, i won't be making my purchases till around Xmas so i'll hold off for a while. I will let you know and maybe you'll still have it lyin' around, if not it's all good. Thanks for the help bro, im'a read up on that package.
Um no. you can get a valve spring compressor from autozone.. free to borrow. You dont need a cam install tool.. you can pull the cam using the water pump bolts and as far as an air compressor... youll havta borrow one.
