CNC'd Edelbrock heads - rocker bolts in the intake ports (pics included)
Old 08-01-2007, 10:07 AM
Pekka_Perkeles's Avatar
Default CNC'd Edelbrock heads - rocker bolts in the intake ports (pics included)
I was installing stock rocker arms into my LS7-based stroker when I noticed that rocker bolts go quite deep into intake ports...:
...so I decided to shorten the bolts a bit. I guess this is ok?
Old 08-01-2007, 10:20 AM
NOBR8KSS's Avatar
Probably fine since that portion of the bolt wouldn't be doing any good anyway!
Old 08-01-2007, 10:29 AM
99blancoSS's Avatar
Yes and recommended that you do, or just use shorter bolts in the first place
Old 08-01-2007, 11:55 AM
ShevrolayZ28's Avatar
Just about all ported heads have that. Make sure you use thread sealer on the bolts that poke through or you risk allowing oil into the combustion chamber.
Old 08-01-2007, 11:56 AM
Dumb Ass Vette Moderator
ls1290's Avatar
Yes. You can even shorten up a couple more threads
Keith
Old 08-01-2007, 12:06 PM
JPH
JPH's Avatar
edelbrock makes shorter rocker arm bolts for this issue #8597.
Old 08-01-2007, 07:22 PM
vettenuts's Avatar
Does anyone know if ARP makes rocker bolts for the LSx?
Old 08-01-2007, 08:34 PM
JPH
JPH's Avatar
i'm pretty sure the edelbrock rocker bolts, will work in factory heads along with factory rockers. arp is making these rocker bolts for them as well.
