lifters
Old 08-02-2007, 06:35 PM
Dragkid1917's Avatar
Default lifters
Im going to do a cam swap, but befor i do this, i would like to know what exactly to look for to find out if your lifters are bad. I hear a tap in the engine thats always been there, but then when i put on my full exaust i herd another one, and it only could be heard at very very low rpm like 400-600. I dont wanto do the rods and a full spring kit and a cam only to be let down by my lifters. Does anyone with experience know what too look for with these lifters?, and how hard they are to change?, and if there a notorious problem with ls1's with alotof miles?
Old 08-02-2007, 06:41 PM
98Camarod's Avatar
You have to take your heads off to change the lifters. I'm putting CompR's in. I had a nasty noise develop on the top end. I'm waiting on all my parts to arrive to finish it up.
Old 08-02-2007, 07:22 PM
you have to take off the goddam heads?.... ahh, how do i know if there bad of not?
Old 08-02-2007, 07:58 PM
3.4camaro's Avatar
Your engine wouldn't work well if you had a bad lifter. A tick is no reason to pull the heads.
Old 08-02-2007, 08:57 PM
98Camarod's Avatar
But if a lifter explodes it will be too late. If you have any doubt that are not good and you are doing a cam swap, spend some extra cash in lifters, head gaskets and bolts, and exhaust mani gaskets. Its easier to change the springs with the heads off. Plus you will not have to deal with the lifters falling in when you slide your cam out.
Old 08-02-2007, 11:05 PM
oh man, im so dissapointed, im, uugh, too much work....
Old 08-03-2007, 12:47 AM
ErikElvis's Avatar
Some ticking is normal. And LT's make it sound worse. They dont hold the drivetrain noise in like the thick stock manis. Im a fan of the "why your in there replace what you can" but It can be more expensive and a hassle that might not even be worth it.
