What do you guys think of this cam?
Old 08-04-2007, 10:31 AM
allthrotle's Avatar
Default What do you guys think of this cam?
I bought this cam and Im having it installed what do you guys think of these specs? I know its not an MS4 or TREX cam but, I think it should still make some good power.(I hope)
Basic Operating RPM Range: 2,500-6,500
Intake Duration at 050 inch Lift: 228
Exhaust Duration at 050 inch Lift: 230
Duration at 050 inch Lift: 228 int./230 exh.
Advertised Intake Duration: 344
Advertised Exhaust Duration: 344
Advertised Duration: 344 int./344 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.585 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.585 in.
Valve Lift with Factory Rocker Arm Ratio: 0.585 int./0.585 exh. lift
Lobe Separation (degrees): 112
Old 08-04-2007, 10:54 AM
TheLS1Kid's Avatar
Its not HUGE but you will see some good numbers with it.
Do you have heads also?
Old 08-04-2007, 10:56 AM
allthrotle's Avatar
LOL yep I got the same heads you do in your sig.
Old 08-04-2007, 11:03 AM
TheLS1Kid's Avatar
Nice, do you have 59cc chambers?
Old 08-04-2007, 11:17 AM
allthrotle's Avatar
Yes sir, patriot stage 2 with 59cc chambers.
Old 08-04-2007, 11:21 AM
TheLS1Kid's Avatar
Cool. Yea you will def make some good power with that cam and the high compression heads.
Old 08-04-2007, 12:37 PM
68birdls1's Avatar
That cam seems like it is close to the comp cam that I am going with. I have researched it and it seems like a really nice cam, pretty good power all around.
Old 08-04-2007, 12:41 PM
carreras's Avatar
Its mild, but u should make great power along w/ the heads. Keep us posted when u dyno ur car.
Old 08-04-2007, 12:55 PM
JPH
JPH's Avatar
look for strong mid-upper rpm trq, and 410+hp with those heads and cam profile. cam specs look right for your combo though. just curios on ICL? i'm guessing it's 108.
Old 08-04-2007, 01:48 PM
allthrotle's Avatar
Yep, Jackpot, thats exactly what it is. Its at the shop now, Ill keep you guys posted on the numbers that I make.
Just so everyone knows this is a trick flow stage 3 cam, that Im using.
Old 08-04-2007, 02:26 PM
98Camarod's Avatar
XER 230/230 .591? Thats what I'm getting and it should be here Monday. Unfortunately my budget doesnt allow for some nice heads, so i bought some 241's with PRC dual springs and titanium retainers off of a member.
Old 08-04-2007, 03:12 PM
JPH
JPH's Avatar
crane hr5 lobe stuff. cam will make good power, and awesome trq. man.
Old 08-04-2007, 05:18 PM
allthrotle's Avatar
I hope so, I originally went with the ms3, but found out that with oversize valves I wouldnt have any ptv clearence. So I settled for this cam, we'll see how she does on the dyno.
Old 08-04-2007, 08:19 PM
68birdls1's Avatar
actually no, I am going with a non XER lobe, it is the 228/230 with somewhere around .585 lift on 112 lsa. Hopefully I am gonna have it all together wed or thurs
Old 08-04-2007, 09:22 PM
98Camarod's Avatar
I should get mine together next weekend. I was hoping to have all the parts here this weekend, but that was a no go. Are you an a4? Let me know what kind of power you make.
Old 08-05-2007, 10:23 AM
allthrotle's Avatar
Those are close to the same specs as my cam. But mines a trick flow cam.
