RPMs jump up randomly
Old 08-10-2007, 10:12 AM
qwikz28's Avatar
Default RPMs jump up randomly
i originally posted this in the PCM section but i figured it would be better off in here cause i got no bites, my issue is as follows:
my dilemna begins with a cam install. i am yet to get the car dyno tuned (everyone around here is packed) so i sent my computer to TSP for a mail order tune. the car drives fine except for the car likes to randomly rev up to about 3-4k. sometimes even when i'm in gear the car will accelerate on it's own. it eventually settles down to idle but at times it takes quite a while to do that. i drove the car before the tune and it did the same thing. so i decided to check the throttle body, everything is normal. the car can be revving somehow even with the blade closed (which i don't understand how) and i also changed the throttle position sensor for good measure. i feel like the new tps helped a bit, but not much. therefore i concluded that it must be computer related. anyone have any ideas or had this happen to them after a cam install? thanks
Jacob
Old 08-10-2007, 01:05 PM
TheLS1Kid's Avatar
I'm thinking it might be a slight vaccum leak.
Did you take your intake off?
Old 08-10-2007, 05:01 PM
qwikz28's Avatar
yeah i did... i can check some of the hoses but does anyone make a diagram of which hoses pull vacuum?
Old 08-10-2007, 05:41 PM
TheLS1Kid's Avatar
The brake booster hose does, and also the real skinny one that plugs in on the passenger side by the MAP sensor does.
Old 08-10-2007, 11:12 PM
qwikz28's Avatar
i'll check them. unfortunately i don't get to see my car until mid week. thanks for the help though.
Old 08-11-2007, 09:19 AM
TheLS1Kid's Avatar
Anytime man.
