Install heads and Cam need help
Old 08-10-2007, 08:35 PM
Trev_SS's Avatar
Default Install heads and Cam need help
I Got problems after my heads and cam insall.
The car will start up but will not run on its own.
the tach also does not work on the gauges what could be the quikeist fix please i need the help know. `
Old 08-10-2007, 09:46 PM
sroach20's Avatar
check your grounds. most of the time the vehicle has trouble running and the tach does not work, its a ground problem.
