Lq9 Block Who Has Them???
I Have A Spun Bearing In My Ls1...i Am Thinking Of The Cheapest Way To Get Car Back On The Road.....is It True That The 6.0 Out Of Sierra And Silverado Trucks Will Allow Everything On A Ls1 To Bolt Up And Run??...and Yes I Know About The Alternator Bracket....i Mean Stuff Like Coolant Passages Through The Heads.....supperting Ls7 Lifters And A Ms3 With 5.3 2.5 Heads....i Appreciate Any Help Or Advice Thanks Guys!!!!!
I have the LS2 6.0L aluminum block its a 4.00" bore also. I got mine at the dealer for $950.00 and every thing off my LS1 ,except the (valley cover) and (timing chain cover) will interchange. The knock sensors will need to be moved to the side of the block near the motor mounts, and you will need the cam sensor wire excitation were the cam sensor is moved to the timing chain cover ,and you will need the LS2 timing chain gear to read the sensor. Thats it.
Originally Posted by ls1leadfoot
12secss Is That Going To Be About The Most Cost Effective Way To Get The Car Going Back On The Road......instead Of Machine Work Stroker Kit Re-balancing All That Good Stuff?
