"Check Engine" light normal after Cam install?
Old 08-13-2007, 07:29 PM
soontobeLS1's Avatar
Default "Check Engine" light normal after Cam install?
Just got my cam install done. Car drives fine, I have unhooked the battery and re-hooked it back up. Still a light.
List of work done.
-Heads taken off, "decked" (or made flat), intake ports "cleaned", exhaust ports opened up quite a bit.
-New 224/224 .563 112LSA TR Cam/springs/pushrods.
-New Underdrive Crank Pulley with new belts.
-Exhaust system was taken off and then put back on.
I am going for a re-dyno tune shortly (already have a LS1 Edit tune on). Will this fix things up?
Thx for any insight.
Old 08-13-2007, 07:40 PM
35thUCF's Avatar
you need a tune, bad
Old 08-13-2007, 08:04 PM
N01SS's Avatar
I wouldn't say he needs it badly...
but yea it'll clean everything up, and perfect is better than fine
Old 08-14-2007, 12:15 PM
radkon's Avatar
Its normal. I had the SES light on when I did my TR224 even though it ran it didn't run very well. A tune will fix ya right up.
Old 08-14-2007, 04:35 PM
RE AND CHERYL's Avatar
Whats the code??? It might be something as simple as you damaged an O2 sensor when you removed the exhaust. If a sensor is bad a tune will do nothing to help ya.
Re'
Old 08-14-2007, 04:50 PM
mr2guru's Avatar
You probably have a P300 (random misfire)
The lope at idle and subsequent rapid short changes in crankshaft speed seem to the computer like random misfires.
Old 08-14-2007, 08:34 PM
blkbird's Avatar
What he said. Thats normal..... Just get a tune and you should be fine!!
Old 08-15-2007, 07:37 AM
408z28's Avatar
If you got a 6sp. car why didn't you go a little bigger???
Quick Reply: "Check Engine" light normal after Cam install?
