Cam Install .. Help with the right Heads??
In a little less than a month when I can find a free weekend I am going to install my cam on my 02 SS (current mods in Sig). I have settled on a Comp Custom Grind Cam -- 231/237 .589 .595 on a 112 LSA .. This is the S15 cam from SpeedInc. Just wondering what you guys would recommend in the right set of heads to compliment the cam. I really like the AFR 225 with 66cc chambers. I would like to keep compression in the mid 11.50 so the heads need to be right.
I'll be doing all the supporting mods with the cam also :
-- Timing Chain, Oil Pump, UD Pulley, Springs, Pushrods
Thanks for any help/info
