getting a cam - newbie
i will admit im still a beginner so i need to double check and ask ?'s bout everything
i just bought a TSP Torquer V.2 cam. 232/234 .595/.598 113 LSA
i know for a fact i need new springs. im not sure about anything else though pushrod/rocker/valve wise. also will be getting a tune as soon as i get it all put together
thanks for the help
thanks for the help
Http://www.ls1howto.com
Read this many times it is all in there.
Now for the cam, TV2 is a nice one but, 112+4 is the way to go or even 111 LSA
If auto you'll need stall, headers, ported TB, at least LS6 intake
If M6, clutch, headers, rear gears ported TB and at least LS6 intake.
^^What he said.
For your valvetrain I would go with this kit:http://www.texas-speed.com/shop/item...d=172&catid=48
You'll probably want 7.4 pushrods. I would keep the stock rockers to help prevent valve float & keep your total cost down.
thanks a lot. ya that write up on that site is very helpful. wats difference does the 7.35 make from the 7.4 pushrods.
also, because i hardly have any mods done to my car as you can tell from my sig, what do you think my next mods should be? i was thinking intake lid and then headers or exhaust not sure which
Originally Posted by KW4life06
lookin at timing chains, 4 the ls2 timing chain should i just get the timing set or would i be good with just the timing chain?
ЯєŧąяĐ Єl¡m¡иąŧøя ™
and and
what he siad
what he siad
I prefer guetting the whole set, while the LS2 chain fits the LS1 set, it is not a perfect fit so for just 30$ extra I prefer going all the way.
