single or double roller chain?
Old 08-16-2007, 09:00 AM
Ceissus's Avatar
Default single or double roller chain?
Search can blow me.
I've decided to get the MS4 cam(i don't want oppinions on my cam choice so don't bother)
I was wondering if you guys think i should run a single or double roller chain?
Also, what size pushrods do you think would be best? I think the basecircle Dia. is the same as stock but i've emailed TSP about it to be sure...
Old 08-16-2007, 10:55 AM
slt200mph's Avatar
LS2 chain will work great for you
Old 08-16-2007, 10:59 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Double is just added weight as far as I am concerned now. There are singles that are just as reliable these days. Like the LS2
Old 08-16-2007, 11:04 AM
vettenuts's Avatar
I went with the Katech single, a bit more money but it survived all the C5R racing without failure.
Old 08-16-2007, 11:12 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
That is very true. on both counts.
Old 08-16-2007, 11:22 AM
slt200mph's Avatar
I am sure the the Katech chain is very high quality as all their parts are and I am sure it has a high quality price tag to go with it. I work in a Chevy dealership and I have yet to see a LS2 chain failure..I put 45,000 miles on the first one I used and put another in when I did the latest cam swap ... for $28 you can't beat it for quality/value. I make over 500 HP and it works great .. anyway I dont plan on running at Le Mans any time soon ..
Old 08-16-2007, 12:11 PM
Ceissus's Avatar
Thanks fellas, sounds like ls2 is the way to go
any suggestions on pushrod length?
Old 08-16-2007, 12:35 PM
01black's Avatar
i used a comp cams 3153KT hex adjust kit...it was that or an LS2 set up
Old 08-16-2007, 03:25 PM
vettenuts's Avatar
Actually, I saw someone who had broken one last week, can't remember which forum (might have been on the GTO sight). Scared the bajeesus out of them though. When I bought mine, the LS2 was still a rumor
Old 08-16-2007, 04:44 PM
0utLawTransAm's Avatar
ms4 is a bigger cam i would go with the double to be safe but im sure the single could work
Old 08-16-2007, 10:51 PM
eallanboggs's Avatar
It's a lot of extra work to swap the chain considering the time required to drop the pan just to remove the one bolt that holds the pump pickup tube flange in place. It's probably worth the extra work to install a double chain if your running big lift with high duration and dual springs. I've done it several times and it adds a lot of time to a cam swap with all the oil pan bolts you have to remove just to get that one little pump flange bolt out.
Old 08-16-2007, 11:00 PM
Tainted's Avatar
7.4 pushrod length, I went with a rollmaster double roller adjustable
Old 08-17-2007, 07:21 AM
Ceissus's Avatar
wow~! tainted posted in my thread~
he's like a celebrity.
back on topic....i decided to go with stock gears and an LS2 chain which is substantially thicker than the ls1 chain.
Old 08-17-2007, 07:34 AM
tonylittle's Avatar
im using a rollmaster double
Quick Reply: single or double roller chain?
