cometic .030 gasket , will work my mods?
guys i have a set of cometic .030 but am too worry that the piston will make a contact with heads after i fix it .
so according to my mods i have the darts and the G5X3 ,so the quistion is
should i use it or not ?? is it safe to go for it? please if there is a guys use that gasket before chime in , needs experts on that .
Originally Posted by DrkPhx
I would go with a .040 head gasket, but you will still have to flycut the pistons.
11Second Club
I'm no expert, but when I went with .040" gaskets, my machinist said that it was fairly extreme and said he wouldn't recommend any thinner. Keep in mind that the piston actually comes up out of the bore by a few thousandths (like .007" or something), so you're going to have less than .030" clearance between the heads and the pistons.
Bill
Originally Posted by Bill Bowling
What is the spec of your cam? I am getting ready to install Dart 205's with my 233/233 and I am using a .040 head gasket.
Bill
Bill
Originally Posted by mudflap1989
You need to tell us how much the piston is out of the hole. Do you know?
but its a stock ls1 block i only changed the rod bolts, i used to have diamond piston before but that motor is cracked with N2O.
so now i only did fly cut the pistons with rod bolts only.
