Anyone running cam only or H/C with stock oil pumps??
Old 08-20-2007, 12:48 AM
regorih383's Avatar
Question Anyone running cam only or H/C with stock oil pumps??
Just wanted to see if any of you guys are running a stock oil pump LS1 LS2 or LS6 on a cam only or H/C car and to see how your holding up. It just seems like a ported oil pump is over kill for a motor thats spinning up to 6600rpms?
ROger
Old 08-20-2007, 01:43 AM
Prerun4fun13's Avatar
for $140, i would rather be safe than sorry and just get the upgraded oil pump IMO..
Old 08-20-2007, 01:49 AM
Tainted's Avatar
ditto, im running a ported LS6 for my P&P 241 heads and 228R
its cheap insurance, along with a good timing chain
Old 08-20-2007, 05:01 AM
Zosickness's Avatar
Stock LS6 oil pump. Spin mine to 7000. My cutoff is set to 7200. Still runs fine. H/C
Old 08-20-2007, 07:01 AM
slow trap's Avatar
stock ls6 pump here also. have plenty of pressure and imo still should have enough volume to handle about any street motor.
Old 08-20-2007, 08:38 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Stock pump on the TA which has PRC 5.3s and MS3. I was also running the stocker on the Z28 in my sig
Old 08-20-2007, 08:45 AM
bjamick's Avatar
Im running the stock LS1 oil pump on my car. Check sig for all the mods.
Old 08-20-2007, 12:19 PM
Ryan02SS's Avatar
Stock pump here.
Old 08-20-2007, 12:26 PM
transamfreak01's Avatar
yeah just get one... its nice insurance and really cheap and i wouldnt run it w/o one. ported ls6 is my vote
Old 08-20-2007, 01:42 PM
FL_BILL's Avatar
I called Lingenfelter's on this issue. I was told that unless you had a crank with additional clearance on the bearings, you didn't need a ported oil pump. So for your setup it really depends on if the stock pump is worn out and should be replaced.
Old 08-20-2007, 08:12 PM
NHRAFORMULA00's Avatar
stock pump here
Old 08-20-2007, 08:53 PM
HAZ-Matt's Avatar
Stock... just GM243s and LS6 cam. I only rev to 6350.
Old 08-20-2007, 09:10 PM
shoemike's Avatar
don`t bother with a "ported" pump use stock or get a hi volume pump.
