What is the order of the main caps?
My stockers had numbers on them. Standing at the rear of the motor you should be able to read the numbers. If you were standing at the front of the motor the numbers will be upside down. #1 goes at the front down to 5 at the rear of the block. 1-4 numbers were on the right side of the caps and #5 was on the left side of the cap. Hope this helps
I have never worked on an LSx type of engine, but Every engine I have ever seen has the bearing tang slots on the same side of the engine. I would assume the LSx is the same. So if the caps are on backwards the tang slots will be on opposite sides of the engine.
