224/230 or 236/242
Old 08-20-2007, 11:21 PM
kistlerjm9's Avatar
Default 224/230 or 236/242
im thinking of going with a custom grind cam over the 224/230 581/588 114. The custom grind will be 236/242 580/590 on a 112. The increase in duration will lower dcr but will be easier on springs as the ramp rate isnt as steep? Let me know all your input. Thanks in advance.
Old 08-21-2007, 12:14 AM
chae's Avatar
Why not make a compromise and run a 228/232
Old 08-21-2007, 01:16 AM
PREDATOR-Z's Avatar
I like your way of thinking
228/232 .588/.595 111+2 if M6 and +4 if A4
Old 08-21-2007, 01:47 AM
Prerun4fun13's Avatar
The Magic Stick 3 is very close to the custom grind you want....
Old 08-21-2007, 02:25 AM
kistlerjm9's Avatar
well now that i have the cam choice what lsa should i go with 112 or 114 its an m6 and im going with the custom cam.
Old 08-21-2007, 04:20 AM
Restricted User
socmguy's Avatar
go with the lower lsa so you can make peak power lower in the band
Old 08-21-2007, 09:57 AM
CHRISPY's Avatar
How about more information on your combo...
Head configuration (stock, ported, static comp, flow numbers)
Intake used (FAST, LS6, LS1 etc)
Trans type Manual or auto
Converter stall and STR (if running auto)
Gearing
Raceweight
Intended use (street, strip, both)
Emissions compliance?
Header type
Cats?
Exhaust (catback, true duals)
Old 08-21-2007, 10:06 AM
KONG's Avatar
Good cam, mine is 228/232 .600/.600 111lsa
Old 08-21-2007, 10:36 AM
Ericbigmac83's Avatar
Would this be fine with stock heads? how would it be dealing with stop and go traffic everyday?
Old 08-21-2007, 10:49 AM
PREDATOR-Z's Avatar
Not an issue with good tuning
Old 08-21-2007, 12:14 PM
JPH
JPH's Avatar
Gearing
Raceweight
Header type
Cats?
agreed. 228/232 or 232/236 is a better place to begin.
Old 08-21-2007, 05:04 PM
kistlerjm9's Avatar
Gearing
Raceweight
Header type
Cats?
stock heads 241's, ls6 intake, m6, 342's, stock gto weight, street 80%, no emmsions, pacesetter 1 3/4, no cats, borla 3.5 inch
Old 08-22-2007, 12:04 PM
helicoil's Avatar
Default Cam
You need a custom cam like a 227/230 LSK/XFI .640"/.605 111lsa +1. It would work great in a stk. head LS1. Just so happens I got a BRAND NEW one, wouldn't fit in my milled AFR headed combo. My heads were 60 cc's with a .038" mill and I only had .060" or so P to V with a .040" gasket and this cam. Really wanted to run it too
Great area under the curve. Peaks around 6400 RPM. Good cammy idle. Lots of torque. It would have a good dynamic compression ratio also.
It would be a good choice.
Make you a helluva deal.
PM me if interested.
Quick Reply: 224/230 or 236/242
