MS3 with 853s 2.02"/1.57 milled .006" ?
Old 08-24-2007, 01:22 AM
floman's Avatar
Default MS3 with 853s 2.02"/1.57 milled .006" ?
A guy is looking at some heads I have for sale. Anybody know if a MS3 will clear on a stock 99 shortblock with 853s with 2.02"/1.57" valves and milled .006" ? How close will it be, or will it hit? MS3 specs 237/242 .603"/ .609" 113+0 LSA
Thanks guys
Old 08-24-2007, 02:08 AM
kistlerjm9's Avatar
should be fine with stock gaskets.
Old 08-24-2007, 02:54 AM
SLP4CamaroSS's Avatar
no you would have to flycutt. i got the same cam almost and i measured .070/.110 and thats close. add those bigger valves and milled heads your going to kiss those pistons with those valves and your gogin to drop the valves and bye bye motor
Old 08-24-2007, 04:20 AM
kistlerjm9's Avatar
what gaskets did you use? i have an ms3 in an 04gto with .053 gaskets and measured .095/.115 which is a long way from what you measured. The .006 mill isnt anything aka .088/.109 which is nominal. The heads also have 2.055/1.6 valves. Im a long way from kissing anything.
Old 08-24-2007, 11:23 AM
my friedn did a 231/237 with 2.02"/1.57" valves and thts w stock gaskets and all his valves where kissing the piston and he droped the valve and tore up his motor now he got a 408
