Oil Pump schim?
Old 08-25-2007, 01:21 PM
flynlow3's Avatar
Default Oil Pump schim?
I was going to get a LS4 oil pump for my ls1 but after reading a few post, Not so sure. I wanted to cut a small schim for my stocker just to boost the oil pressure a tad. Does anyone know how the deminsions this schim has to be? I looked at SLP's version and it seems like it would be very easy. I plan to get an aluminum rod of that size and just cut a piece off the end. What are your thoughts?
This would cost under $5.00. Is it worth it?
Old 08-25-2007, 01:29 PM
JPH
JPH's Avatar
volume is needed more than pressure.
Old 08-25-2007, 01:52 PM
StevieZ's Avatar
Maximum thickness shouldn't exceed .120"
Old 08-25-2007, 01:59 PM
flynlow3's Avatar
would the updated LS4 pump work on a c5 with stock oil pan?
