Rebuild Question
Rebuild Question
Does this look like a good lineup for parts do they all match up what else do i need?
Qty Part # Product Amount Total
121-CSC6125DS2A2A Callies CompStar Connecting Rods, 6.125" length, 2.100" crank pin, .927 wrist pin, LS1/LS6 $599.99 $599.99
126-11518 Diamond Pistons LS1 Forged Flat Top Piston set w/ -2cc Valve Reliefs, 4.000" BORE / 4.000" Stroke / 6.125" Rods / 1.120" Comp Height / .927 x 2.500 Wrist Pins Included $695.99 $695.99
126-09064000 Diamond Pro-Select Piston Rings, 4.000 Bore, 1.5 - 1.5 - 3.0 mm $179.99 $179.99
83-AFR-1630 AFR 225cc LS1 Cylinder Heads with 72cc chamber assembled with 2.08" / 1.60" Valves, dual coil valve springs(.600" max lift), and Titanium retainers. $2475.00 $2475.00
179-QTEC60 Quick Time Performance Electronically Controlled Exhaust Cutout - Dual 3" Valves Only $304.99 $304.99
Options
179-200198 Quick Time Performance 1-3/4" Long Tube Stainless Steel Headers with 3" High Velocity Collectors, 1998-2002 LS1 F-body (Race style) $724.99 $724.99
Order Total: $4980.95
Options
