Big cam what plugs?
Big cam what plugs?
I just pulled the plugs on my car and with the new cam it seems that the plugs are slightly sooted. The air fuel ratio on the dyno was just about right on. What should a typical plug look like with a big cam? I am currently running NGK TR55's should I be using something else? Cam is in signature.
Originally Posted by Dragkid1917
what was ur SAE numbers.... 393 for that cam seems low, was your converter locked?
Converter was locked. It really doesn't help that I have the worst ls1 heads possible. Those numbers are the corrected ones.
