Stripped spark plug thread, how to fix?
Old 08-27-2007, 06:56 PM
Doc99SS's Avatar
Default Stripped spark plug thread, how to fix?
As in title, stripped only the #8 thread. Do a buy & install an hela-coil (sp) ?
Old 08-27-2007, 06:59 PM
Moderator
davered00ss's Avatar
Call patriot and see what they can do about them.
Old 08-27-2007, 07:01 PM
Kleeborp the Moderator™
MeentSS02's Avatar
Pull the head so you can heli-coil it.
Old 08-27-2007, 11:09 PM
massls1guy's Avatar
Long shot here. I saw a tool advertised in a Mustang magazine (sorry...). Anyway, it was a hollow tap where the tip collapsed to a small diameter. You put it through the stripped plug hole then screwed this plug down the middle of it to expand it to the full size. Then you threaded it backwards out the threads pulling any metal shavings with it.
Old 08-28-2007, 12:51 AM
nofearracing28's Avatar
I would say that it'd be alot less time consuming if you just pulled the head and got it from there. But then you'll have to get new head bolts, gaskets, ect ect.
Worth it IMO.
Old 08-28-2007, 05:05 AM
Restricted User
socmguy's Avatar
D'OH!!! ouch man! Time for new heads if you've got stockers!
Old 08-28-2007, 08:51 PM
Doc99SS's Avatar
I have a few other posts around, what happened is that I blew up my modded LS1 engine in my '99 SS. The passenger side head is off. Looking down the #8 cylinder, all I see is a debris field, this piston is totally gone, shattered into a dozen or more pieces.
The spark plug hole thread got buggered up because the spark plug tip got bent over and as I turned the spark plug out, the spark tip electrode stripped the tread. I am really screwed up right now! In the other treads, I am looking for advice on a short block. Oh, BTW: the block has a 1 1/2" hole in it, just above the starter motor.
Old 08-29-2007, 12:39 AM
CaliboyTA's Avatar
best if u take off ur heads and send them to a machine shop to helicoil them. i stripped #6 and #1 and i got them helicoiled. no problems with them.
Old 08-29-2007, 06:46 PM
Doc99SS's Avatar
Yea, I agree. My intent is to pruchase or build a short block and re-use the Patriot Perforance heads. I will get them re-conditioned and helicoil that stripped plug hole.
Quick Reply: Stripped spark plug thread, how to fix?
