Will it pass CA smog 227/236 .600/.600 114LSA
Will this pass CA smog
LS2 block
Callies rods
Wiseco pistons (right around -28cc dish)
Callies crank (no need for a HIGH DOLLAR crank)
AFR 225 64cc heads (or something with a THICK deck)
8.9-9.0:1cr
clevite bearings
LS6 lifters
Comp 921 springs
Comp pushrods
Cometic .051 MLS gaskets
ECS 8" crank pulley
ARP main and rod studs
ARP head studs (Unless stock deck. Then ARP L19 studs)
Stock 1.7 rockers (no need for rollers, DONT go 1.8's)
cam is a 227/236 .600/.600 114LSA will it idle close to stock?
LS2 block
Callies rods
8.9-9.0:1cr
clevite bearings
LS6 lifters
Comp 921 springs
Comp pushrods
ECS 8" crank pulley
Originally Posted by Tainted
hell no
the 224/224 .581/.581 on a 114lsa BARELY passes
EDIT: I thought a 224 on a 112 is the cam that "barely passes" with a dead on tune.
Originally Posted by dyls1
And what exhaust are you going to be running? Seems like a big cam for manifolds/shorties with cats.
well i live in cali too(bay area) and if ur check engine light comes on u fail which it might sinceu put an ls2 in and they are very strict about modified exhaust like long tube headers but u can always take it to the referee in sac and have himcheck it out he will pass u if it blows clean enogh
hell no
If your gonna boost it, you don't need that big a cam. I've seen GNXs running in the 9s with cams in the 205-215 range.
As far as how it will idle... I've got a MTI stealth II with 224/220 on 116LSA and it is scarry how much the idle sounds stock. My MAC mids and BOrla catback do a fine job of covering up the sound of the cam.
Re'
Re'
I know the LS7 cam is legal, but how much power will I be leaving on the table?
Re'
Re'
wont pass. I've seen bigger than a 224/224 112 pass, but would not recommend it.
I'd look at something like a 220/232 114 You can use the 219 LSK or 220 XER on the intake. Maybe a 220/236 115.
You aren't leaving that much on the table. You can always add a small shot of NOS.
will the ref pass me Long tubes if i blow clean?
i dont think so because it would be considered modified exhaust and there bitches about it i would like to put a new engine in to replace my ls1 but i pretty sure it would have to blow as clean or cleaner than my stock ls1 which i doubt
