Any good lsx shops around Ohio?
Yep, thread title says it all. I'm looking for a good shop around Ohio to do some machine work. W2W will not do my work because apparently its not "performance oriented" enough. I want to do the final assembly but will need to have the block (new ls2) machined. Really do this build on a budget, hence the reason I'm assembling myself. Any help is appreciated.
there are a few good ones if you want to come to dayton, check out www.dayton-fbody.com or if you want columbus check out www.cofba.org
