Can you????
Old 09-01-2007, 05:03 PM
2002RamAir's Avatar
Default Can you????
Hey guys...
Can you change the pistons and rods without pulling the motor? Or would i wanna get some machine work done when changing the pistons??
Thanks
Old 09-01-2007, 05:21 PM
dyls1's Avatar
No. Yes.
5_02ls1's Avatar
yes you can as long as the engine is suppoerted....the k member will have to go and of course the heads....just check the cylinders with a bore gauge when you get it all apart......
Old 09-01-2007, 05:24 PM
5_02ls1's Avatar
Default .......
Originally Posted by dyls1
No. Yes.
why not we change rod bolts when the rod bolts are out if the heads are off that piston will push rite out....
hell you could pull the tranny and do a crank install as well........
Old 09-01-2007, 05:50 PM
68chevypu's Avatar
yeah but you cant just throw new pistons in an old cylinder, there are ridges inside the cylinder that will snap new rings.
68chevypu's Avatar
and I mean if you are gonna go so far as to remove the k-member, why not just drop the whole motor and do it right?
Old 09-01-2007, 09:01 PM
dyls1's Avatar
So I guess I am wrong, just pull the k-member and leave the engine hanging from whatever is available. And then have at it, best of luck to you.
I would go the other route and start by yanking the engine, but that is just me.
