need help with rocker armss 1.7 or 1.8
I just got a 02-04 z06 cam and heads brand new with the yellow valve springs. im wondering if i intall 1.8s will it make my cam run like its alot bigger then it is . or should i just get the stock 1.7s
changing rocker ratio puts more strain on the rockers and the valvetrain in general. You are giving the cam more duration and more lift, something you should have done when you swapped out the cam in the first place.
Stick with 1.7s. In fact, stick with stock rockers unless your heads require you to change them. Some aftermarket heads have a change in valve angle, which requires a roller rocker.
Originally Posted by flynlow3
You have to watch out for PVC when going to a 1.8 ratio as well. A small cam shouldnt matter but its always best to check and be safe than sorry.
