224r or 228r TSP CAMS WITH STOCK STALL
How will either of these cams work with the stock stall? Also whats the difference between the TSP 224 and the TSP 224r besides the higher lift? Also how much of a difference between the TSP 224r and the Thunder racing 224?
224 will be better than the 228, but both would benefit from a little higher stall. I have a friend with a 224R and a 3000 stall that runs high 11's in a heavy -a$$ GTO.
Difference between 224 and 224R is XE cam lobes versus XE-R cam lobes. Just a different profile and the XE-R's are a little more aggressive.
Not sure on the 224R vs TR224, I think the TR224 is a different lobe design with different valve events. Difference in power and how they drive would probably be small.
