trick flow heads what pushrod length
need some help 1999 ls1 with 595 cam trick flow heads,what pushrod length?
head cam kit came with 7.700 and they didnt work,car ran with alot of valve train noise and 300 miles later tips of 3 push rods gone all tips worn,the 3 really worn ones are about a 1/4 inch smaller,do you needs to shim the rocker stands? using harland sharp non adjustables.trick flow said 7.500 are the proper length but there to small. need advice
I agree....... A 30 dollar PR ckecker will save you a grand worth of new PR's, lifters, cam, and labor.. Cause if you wearing them down that bad, your more than likely destroying everything else..
Originally Posted by ls2 bait
so id say 7.425-7.400. easiest way is to get a pushrod legth checker. takes the guess work out of it.
