Looking for some info about Accusump oil system
Looking for some feed back about the Accusump system in a drag race set-up. I am thing of using it on a street/strip solid roller 8,100 rpm wet sump set-up. I understand that it is a good system for preoiling and prevent short oil starvations.
I am more concern about high rpm lubrication and reducing aeration.
Any feed back on the Accusump system, or how to reducing Oil Aeration in wet sump system.
Bob
Bob
I have one of the Moroso ones and I'm not sure about aeration of the oil, but apparently you could reduce windage by running a little less oil than the thing holds which means a little less int he pan, but not sure how comfortable I am with that idea. Wonder if aeration would also have to do with what kind of windage tray you have. I imagine if you had too much air in the oil would it show up in your oil pressure reading?
Motor has not been built yet, just looking ahead to prevent any oiling problems.
Plan on using a Moroso pan and Mellings pump with an external oil filter. Looking for some feed back about the Accusump system as it sounds like a good set-up for that little extra margin of safety.
I like that it oils the engine before you start the car. I have the solenoid valve actuated by the ignition. I just run a stock pan, melling 55 pump with a white spring and I usually have 40# at idle unless it gets hot, then maybe 35# and usually 60-70# at cruise - and also WOT. I have coated Clevite bearings and the diamond stripper windage tray and a crank scraper too with a pan baffle at the pump. Nothing more complicated than that.
I am looking for the best place to plum into the oil system. I understand there is three ways, in the front or rear of the block or into the oil line to the filter.
Any LS guys using this system?
I have used the system on a few LS engines. It will work best plumbed into the rear of the block, low or high behind the intake. The front port is unfiltered oil, and may damage the bore of the accusump over time. If you use the port behind the intake, it may need to be enlarged. Some of the blocks have a very small transfer hole there that would limit the function of the accusump.
Kurt
Kurt
Kurt
Kurt
Bob
I have a Canton 3 quart Accusump brand new in the box with all the required hardware for installation I'm selling if you're interested. $250 shipped, which is over $100 off the price buying it elsewhere.
Kurt
Kurt
Manual switch, so when I turn the key to 'accessory' I flip the sump switch, to pre-lub the block, then turn it over.
Granted my vette is not for drag racing but running road courses.
