loose front cam retainer??? WOW!!
Old 09-07-2007, 09:07 PM
ls1builderss's Avatar
Default loose front cam retainer??? WOW!!
So would a loose front cam retainer plate cause low and fluctuating oil pressure? Guess why i'm asking
Old 09-08-2007, 09:22 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Haha! that sucks. No telling what kind of hell you might have been putting your knock sensors through if it was moving around horizontally. How did you find out?
Old 09-08-2007, 09:33 AM
JPH
JPH's Avatar
very good possibilty.
Old 09-08-2007, 09:36 AM
myfast70's Avatar
That cam retainer plate also has a seal on the back side of the plate that seals against two ports on the block.
Old 09-08-2007, 09:41 AM
JPH
JPH's Avatar
bingo! oil for lifters galley if i'm not mistaken.
Old 09-08-2007, 09:44 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Jesus. That could be catastrophic if you have oil leaking down from the top end too quickly.
Old 10-09-2007, 11:40 AM
tell me about it. I was laying there under my car about to start freaking out because i was afraid I was going to have to yank my engine, when I just happened to look thru one of the holes on the cam gear and seen bare threads showing. I knew instantly that was it. apparently the seal blew out and caused the bolts to become loose. I loctited those bitches good this time (thought I did that the first time around?)
Old 10-09-2007, 04:40 PM
GuitsBoy's Avatar
As mentioned the oil galleys would leak straight down into the pan. This would certainly cause low oil pressure.
