ls1 valve cover baffle
Old 09-10-2007, 08:32 PM
flynlow3's Avatar
Default ls1 valve cover baffle
How bad is it if you have a set of vavle covers and the baffling up top was removed for an ls1? I have a set with no baffles and wondering if I should use them or not.
Old 09-11-2007, 02:35 PM
GuitsBoy's Avatar
You may pull some excess oil through the PCV, but then again, it may not be much more than normal anyway...
Old 09-11-2007, 05:06 PM
vettenuts's Avatar
If you switch to the LS6 valley cover, no issue at all. The PCV won't plug into the valve covers to draw air. I am in process of this right now, just picked up two valve covers and the valley cover off of fleabay for this very purpose.
Quick Reply: ls1 valve cover baffle
