Changing the block by myself. how hard?
Old 09-10-2007, 11:18 PM
The PAT WS6's Avatar
Default Changing the block by myself. how hard?
since my bottom end went out i was gonna have TRT do it but now im considering doing it myself. what do you guys think. ive done it all from rear ends to clutches to H/C swap. how hard is it honestly to pull the motor. and is there a write up. can u pull it just by disconnecting the bell housing?
thanks.
Old 09-10-2007, 11:41 PM
Sex On Wheels
will69camaro's Avatar
Pulling the motor is easy...I pulled it out of the top (hard way) and it still wasn't bad.
William
Old 09-10-2007, 11:48 PM
Websy21's Avatar
I say go for it. I am going to be doing it with a complete turbo setup this winter and I haven't done a swap before. Your only capable fo doing whatever you think you are, to a point, LOL. Just read up man, whenever I am in doubt thats what I do, than its gravy. I am a ways away from doing this project so I haven't researched in depth much yet but I will be. Shouldn't really have to though. Put it back the way you took it out. My cousin who's a mechanic told me thats how he learned Go for it, especially since you've done a H/C install, etc already. Everyone that I talked to who's done it said its not bad at all. Just looks deceiving when you look under the hood.
Old 09-11-2007, 12:02 AM
wheres the write up at to pull it from the bottom that way i dont have to get a cherry picker.
Old 09-11-2007, 12:44 AM
Websy21's Avatar
Only problem with that is how are you gona get it up that high. You'll probably need a picker to get the body up that high. Could be wrong on this but thats the only way I've seen it done. I can't find any write ups either. Everybody pretty much says to start pulling wrenches, LOL
Old 09-11-2007, 12:50 AM
Da Swami's Avatar
Yeah, if you go the "drop" route you have to either have a lift or a cherry picker to pick the body up off the k-member/engine.
Old 09-11-2007, 01:00 AM
Websy21's Avatar
Thats what I thought, either way you'll be fine. Guys that have done it both ways say that its easy either way. I'd really like to drop it too but I might be pullingn it from the top. I'm not gonna worry about it, both will work fine.
Old 09-11-2007, 12:09 PM
ive seen write up somewhere and i cant find it now cus i never thought id be pullin my motor.
Old 09-11-2007, 01:29 PM
71velle's Avatar
this one http://www.michiganspeed.com/enginepull/index.html i do remeber seeing another one but dont have the link ill be using this way to pull my motor also just put out a bearing
Old 09-11-2007, 01:45 PM
Websy21's Avatar
thanks for the link, I'll refer to this too
Old 09-11-2007, 01:51 PM
Blck_01ss's Avatar
Go pick this book up at your local book store. Great book! How to build High Performance LS1/LS6 V8's by Will Handzel. Gives you step by step procedure on how to do it. I'm in the process of doing this right now and it's helped me out alot! Good luck trying it w/o a Hoist/Cherry picker lol.
Old 09-11-2007, 03:30 PM
71velle's Avatar
yeah without a Cherry picker your gunna have an issue if you honestly have to go look at rental stores the ones that rent tools and **** they usally have cherry pickers
Old 09-11-2007, 06:43 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Anyone have that old pick of Jrod's Camaro when he ghetto jacked it up with boards and wheels?
