427 equivalent of 224/228/114?
Old 09-12-2007, 06:49 AM
Gannet's Avatar
Default 427 equivalent of 224/228/114?
Assume you wanted the exact same idle and powerband characteristics that a 224/228/114 gives on a 346, but for use on a 427. What would you run?
Old 09-12-2007, 07:05 AM
slow trap's Avatar
someone like patrick g or pred would be the ones that know more than most of us on here but just on a guess i'd say something around 12-14 * bigger should be pretty similar so i'd say a 236/240 or a 238/242 or so.
Old 09-12-2007, 08:26 AM
mr. Jones's Avatar
i will not take a shot at your question-but
if your using ls7 style heads and not ls1/6 heads
note that the flow characteristics are different.
the ls7 heads require a larger split (more exhaust duration) between intake and exhaust
Old 09-12-2007, 11:12 PM
jermzz's Avatar
I read somewhere is was 7 - 8 degrees per 50ci. I dont completely remember though.
Old 09-13-2007, 07:15 PM
z28ss4me's Avatar
Ok, I have no frickin' idea, but I have to believe this isn't the right formula, because if you used this math and kept going up at aroun 800ci, you'd have a 360* lobe, hmm don't think that works.
I think whatever the math it has to effect base circle as well. Well at least at some point as you go up on ci.
Of course I have no idea, so I'm just throwin that out there.
Old 09-13-2007, 08:13 PM
LS1 Tech Administrator
Patrick G's Avatar
13-15 degrees bigger will get you there, but remember, the LSA will depend on the heads you run. Small valves and ports will favor a cam with more overlap and will respond with a narrower LSA. Higher compression will favor a wider LSA. Longer stroke will favor a wider LSA, but it's trumped by the cylinder head so choose accordingly.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 09-14-2007, 06:56 PM
NoMoreFWD's Avatar
I agree. I remember when I suggested a 110 over something like a 112 lsa for an LS1, and was asked why. I stated the decision was based on valve size and a couple mods on here gave me a WTF. Maybe they will believe it now.
Old 09-16-2007, 07:47 PM
Gannet's Avatar
Thanks for the replies.
Old 09-16-2007, 11:29 PM
jermzz's Avatar
neither does a 800ci sbc motor.
