View Poll Results: Huh?
Weld it and use it
8
28.57%
Cut your loses and start fresh.
20
71.43%
Voters: 28. You may not vote on this poll
Would you still use this block?
Old 09-13-2007, 10:12 AM
snketr's Avatar
Default Would you still use this block?
It's a 6.0 block that's already been bored, honed, new cam bearings, the works.
It got dropped
Use it with the piece welded back on it, or scrap it and cut my loses.
Old 09-13-2007, 10:16 AM
allngn_c5's Avatar
That FN sucks bro. I don't know, I think I'd start over. Not an expert though and it is amazing what a good welder can do. Good luck.
Old 09-13-2007, 10:19 AM
snketr's Avatar
I can get it welded for free. But do you think it'll throw everything out of whack?
Old 09-13-2007, 10:20 AM
Ferocity02's Avatar
That thing is fubared, time to make a coffee table out of it! I'd be worried about other damage that you can't see. The block may not be square anymore, the bores and journals may be out of round. Also, welding that back on, if you can, will put a lot of heat stress on the block, warping it even more. Sorry to hear man, time to start over. Luckily those blocks are pretty cheap.
Old 09-13-2007, 10:27 AM
Ericbigmac83's Avatar
I say weld it up, see how it looks, sleep on it for about a week, and then make your decision. It could go either way, i dont think youre really gonna warp anything from welding there as long as the guy is careful
Old 09-13-2007, 10:29 AM
bczee's Avatar
It is possible to weld it back together, but I would be concerned with the oil gallery plug. I would consult the welder and a engine builder once it is repaired to have to block inspected and re-machined.
Old 09-13-2007, 10:46 AM
SparkyJJO's Avatar
I'd play it safe and replace it. Sucks I know but would be the safest route.
Old 09-13-2007, 10:55 AM
8a8mfh's Avatar
Can you go into detail about the free cast iron weld?
You might get the piece reattached for free with a nickle stick weld.
In order to repair that properly the block needs to sit in an oven and heat up slowly, then get properly welded and cooled down in an 8-12 hour time period.
Thats a hell of a lot to give away for free.
Old 09-13-2007, 11:01 AM
snketr's Avatar
I work in a PVF, refridgeration, mechanical supply house. I've got 1000's of professional welders at my disposal. A refridge guy that does cast iron all the time said he'd do it for me.
Old 09-13-2007, 11:06 AM
Sharpe's Avatar
How did that happen?
Old 09-13-2007, 01:08 PM
5.3LJimmy's Avatar
I don't like the fact that it got into the oil galley, therefore wouldn't use it. That definitely sucks.
Old 09-13-2007, 01:59 PM
8a8mfh's Avatar
I happen to work in the refrigeration industry as well. I'm assuming these 1000's of welders do pipe work. Thats way different than a cast iron block. He may be able to do it, but it won't be a proper engine block repair.
PVF for everyone else is Pipe, Valve, and Fitting. The problem is the engine block acts as a huge heat sink, you can preheat it with a torch, weld it, then cool it down with a torch. Thats how they do the pipe, but the pipe does not suck up as much heat.
You HAVE TO have an oven to put this block in and it needs 8-12 hours to cool or else it will crack. It needs to cool down in steps inside the oven.
Old 09-13-2007, 02:53 PM
snketr's Avatar
They have an oven, but I'm leary of doing it and then building an engine. I was just seeing what others thought.
Old 09-13-2007, 05:18 PM
ApexVIII's Avatar
naa get a new one if you got the money
Old 09-14-2007, 06:06 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
I'm also wondering on how some one dropped that? I know they're heavy, but still....
Old 09-14-2007, 07:36 PM
DONAIMIAN's Avatar
Fe blocks are cheap depending on where they come from. I would just get a new one.
