Best heads for Torquer 2
Looking to purchase me some heads as a birthday present, I have the Torquer2, whats a good set of heads to go with it? Thanks Matt
i went w/Patriot Performance Ls6 "Style" heads (2.02int/1.57ext), 59cc...
now, i dont have a Tv2, but a comp 224 .581 @112lsa and putting down the numbers in my sig...
Gunnar at Patriot was great to deal w/and I have had no issues w/these heads. got mine for around $1000 from a guy new...
a good bang for the buck would be a ls6 head ported if you can afford it stage 1 or 2 would be plenty anuf i wouldnt mill them and just run a .40 mil gasket i made 428 rwh and 411 rwt on a mustang dyno i got mine from patriot $500 for heads guides and new valves couldnt beat it there not ported thow i gainded 28 h and 11 ftp with just swaping the heads i go to the same dyno every year and that was the only changes i made to the car that year i was happy
what is the difference between the LS6 and 5.3L heads (assuming both are the PRC stage 2.5 heads)? The 5.3 has higher compression then the LS6 heads? Which ones flow better?
which will give u more power on a head and cam setup?
i think the ls6 heads will outflow the 5.3s by a little bit. not much though.
something to consider is the size of the intake runner between the 2.
i think the 5.3s are somewhere around 220cc....which isn't great for low/mid range pwer and torque...but it's not bad either.
i know some of the ls6 heads a few years ago were in the high 22x and low 23x range.
something to inquire about with the company
