427 stroker cam???
427 stroker cam???
what kind of grind should i look for in this kind of cam?
it's going to be a street car so i want a desent idle, but i also want the redline as high as i can get it, nothing north of 7000rmp tho...the motor is for roadracing so power under the curve is important to me
any thoughts?
any thoughts?
Just call comp directly or one of the suporters of this site. Many of them can place the order for you and have it drop shipped. I always use texas speed. Just call one of them with the spec Predator_Z gave you. And yes! every cam that I have seen this guy recommend has performed exactly as he said it would. Go for it, should result in neck snapping torque......
