How to destroy a perfectly good motor with a 10 cent washer
I had this on another board, but I need some help getting this sorted out. I want to get this engine back together and built just for stock. I will at least need the block resleeved and one new piston with rings to replace what happened. Here are the details.
I was chasing a small vacuum leak and removed the intake from the engine. I have the washers that came with the FAST under the manifold cap screws to help spread the load. When I took the manifold off I didn't notice but one of the washers came off the cap screw and rolled right into the number 7 hole. The valve must have been wide open because the damage is only in the cylinder. the bowls are clean.
It was late, I was tired, and I've had this manifold on and off so many times I was sloppy. Below are some pics that will tell the story a little better.
I am sussing the situation with Tony Mamo and as soon as we know more I'll post up on the direction I'm going to go with. I don't have much money right now, so I'm thinking Forged 347, or if Tony can do some magic on the heads maybe a forged 402. More will be revealed...
The major damage to the head
cylinder - crack on the right, gouge on the left, broken ring land in center
closeup of broken ring land
custom valve reliefs
overall shot of the chamber - note the minor damage on the top quench pad
the sucker that made this all possible - with my help...
How's that for shooting yourself in the foot? I'll document this as I go along, the teardown, build-up, etc. Might as well fess up and publicize it..
Too bad, it was a sweet running motor... The next one will be
The heads don't look too bad. Ive seen chambers with a lot more damage have repairs done. LS1 blocks can be had for a couple hundred bucks now, and pistons and rods are starting to come down in price. Hell if you wanted to stay on the cheap you could just get a set of forged pistons for the stock rods (if theyre not bent) and you would really be able to keep cost down.
that head can be fixed cheap. and if those are shelf pistons, you can get one with rings for cheap too. rods are usually sold as a set so you might pay there. and ls1 blocks are cheap as crap now too. i'd say the most expensive part will be labor to put it back together.
Actually dude. If I were you (unless you know how to build a shortblock yourself)
trash everything but the heads and cam. Get a new 347 from like TSP which is like less then 3k and throw your heads (after you get the one repaired) and cam in it.
after you buy a new piston, new rings, rods, block, pay a shop for rebuild labor, etc, you could have bought a new shortblock which will be way more reliable.
That sucks man. We've all made our mistakes. Some big, some small. I think it comes with the territory or working on our own stuff. If it makes you feel better, I caught my car on fire last year at the track when a fuel line came off during a run and started dumping on a header. Same situation, tired, in a rush, etc. +1 on a reason to go bigger and better.
The upside is that you can buy a brand new LS6 long block (caddy motor) from a GM distributor for around $3k. It is the exact same motor as the LS6 Zo6 motor. There was a post on another forum about it that I saved to my Firefox favorites. I am not at home right now, but later (if you're interested) I could post the link and part number.
Thanks for the kind words and also the humor. Can't lose that for sure. Since I posted this I posted another thread after I talked to Tony Mamo and here is what I am going to do. https://ls1tech.com/forums/generation-iii-internal-engine/784215-more-10-cent-washermania.html The link contains the motor workup and associated components. The really big thing I want to do now is get the block resleeved and buy a new piston so I can put the motor back to stock. I'm thinking of putting it into my truck. Can anyone help with a recommendation of a shop in NJ near Bergen County (Northeast NJ) that can resleeve that block for me. The only thing wrong with it is the crack in the cylinder wall.
