low oil light on?
low oil light on?
well, this has been going on for about 10 months, i check the oil level and its perfect, even after an oil change it still says low oil, i replaced the oil sensor on the opposite side of the bleed bolt on the pan, and it still reads low oil, sometimes the light dosnt come on , but most of the times it does, is there another sensor i need to replace?
Closed Sponsor Account
I wouldn't worry about it. Do you park on a decline or incline at any point? I see that you are in LA, perhaps your car sits on a hill and the oil puddles to one side of the pan or the other?
I would check oil levels OFTEN! If you are good with the oil, you should have no problems.
Double check all connections and wire conditions of that sensor!
Good luck
Erik
Good luck
Erik
