Machined my balancer!
I was curious if anyone else had done this, I had a buddy of mine who is a machinist machine the back part of my balancer off, the section where your AC belt would go. He did not take out any part of the center section that actually holds it together, just about an inch or so off the back. Anyway, it knocked off about 8lbs off of it. I'll download the pics in a little while and post them.
BTW the machining was done before the balancing of the bottom end. It's not like I pulled my balancer off of a motor that was already together and had it machined on.
UNDER PRESSURE MOD
Well, I've been wrong before, but I still think it would be better to drop the weight off the flywheel since it has a larger diameter, which requires more inertia to rotate. Any pictures of the balancer after modification?
I'd think that this could be an option for those guys who got rid of their a/c.
Originally Posted by vettenuts
It is a harmonic balancer, not a pulley. It is old school SBC, both run crankshafts, both develop harmonics as a result.
Its a dampner with a pulley, not a balancer.
Originally Posted by The Alchemist
Okay, so it's a harmonic dampner, no balancer. My bad, used the wrong termonology, but still, conveyed the same point.
Eurospec2, can you elaborate on your experience when you ran without the front pulley? (You did say 'ask me how I know')
Originally Posted by N4cer
It's not really a balancer in our case. It's just a zero-weight pulley. It serves no balancing/damping purpose. This isn't an old-school SBC ya know.
Good stuff, BAKED.
Good stuff, BAKED.
You don't want to knock weight off the fly wheel, the fly wheel is used for momentum, it stores the rotational energy. Personally, I wouldn't **** around with the rotating assembly just to knock off some rotational mass.
Originally Posted by Eurospec2
No, it does not perform as a balancer like the old small block chevy, you can remove the front pulley from an LS1 and your motor will still run fine, just leak a bunch of oil (ask me how i know )
UNDER PRESSURE MOD
Both a heavy and light flywheel have their plusses and minuses. For an 1/8 mile car, the heavier flywheel will be of greater benefit, but I've read where people have gained et and mph going with a lighter flywheel and offsetting it with a slightly higher rear gear, i.e. 3.73 to 4.11.
